i am running higher boostConsidering the OEM spark plugs are designed to run 100,000 miles before requiring replacement. If you're not running higher boost there's no need to upgrade. Just wasting money IMHO.
Okay... so have you read your stock plugs? Are you seeing something abnormal?i am running higher boost
No, I am not...just want to be sure I am not missing out on anything. Most people tell me that stock is fine and that it will not make much of a difference, but I like to hear different perspectives.Okay... so have you read your stock plugs? Are you seeing something abnormal?
If the amount of boost you are running is not resulting in spark blowout and the plugs read properly then stick with the stockers. If you are seeing some spark blowout try reducing the gap by .002 and see if that helps. Depending on how the plugs read you may need to drop to a colder plug. However if you're not seeing any indications there's an issue with your stock plugs I'd just leave them alone. Don't fix what ain't broke!No, I am not...just want to be sure I am not missing out on anything. Most people tell me that stock is fine and that it will not make much of a difference, but I like to hear different perspectives.
