i would try connecting a pair of test wires directly from the battery to the horn terminals and see if that works. If it does, then start tracing your factory wires back to the ground connection and also the horn switch. You may find an open connection. But if the horn still does not work even with your test wires directly connected to it, then the horn itself is bad and needs to be replaced.
