Since the fuse isn't blown try plugging in a different 12-volt accessory and see if it works. Maybe it's not the power plug, it's the device you're plugging into it that has failed.my in dash power outlet stopped working, I checked the fuses and they were good. Does anyone know how to get the power outlet out? is there anything I can do instead of removing it?
its the power outlet, nothing I plug into it works, but all the stuff works in other outlets. I can't get the socket out of the face plate, there are no videos on how to replace it or remove it. I'm sick of this car already. I've had electrical problems, engine problems, a/c vents break, the car is just one problem after the next.Since the fuse isn't blown try plugging in a different 12-volt accessory and see if it works. Maybe it's not the power plug, it's the device you're plugging into it that has failed.
Sorry to hear you're having so many issues.its the power outlet, nothing I plug into it works, but all the stuff works in other outlets. I can't get the socket out of the face plate, there are no videos on how to replace it or remove it. I'm sick of this car already. I've had electrical problems, engine problems, a/c vents break, the car is just one problem after the next.
I got to to the power outlet, I can't seem to actually pop it outSorry to hear you're having so many issues.
To replace that 12v power outlet you'll need to remove the face plate which surrounds the stereo system. Doesn't look to hard to do. Watch this: https://www.youtube.com/watch?v=14JftiZLN88
So you removed the radio face plate and now you can't remove the power outlet from the face plate?I got to to the power outlet, I can't seem to actually pop it out
