1 - 5 of 5 Posts
Well in the company from the sunny Greece,
The car has made only 14,000 thousand kilometers,
The first oil change in the 7,500 kilometers was missing about a liter of oil.
Today at 14,000 I added another liter. Is it normal?
From the exhaust does not smoke. Only occasionally climbs a cloud and then ends.
Mine has just a little more miles than yours, 10,000 miles or about 16,000 km, and mine doesn't do that. I've never seen any smoke from my exhaust.
I know there was a problem with the early 2015's and the stock crankcase vent oil separator (TSB 15-0192). Thing is you said there's no smoke coming from the exhaust... so I would think it may be time to take it to the dealer and have them check it out for you.
Sometimes it has pulled out of smoke evaporation for a minimum, not always,
What does that mean i damage?
No idea Giorgos. I suggest you start by having a "leak down" test performed to check cylinder pressure and ensure there's nothing wrong with the rings or valves.
1 - 5 of 5 Posts
