Depo Racing Mustang Ecoboost Intercooler for the 2015+ Turbo 2.3 is a direct bolt-on replacement intercooler designed to drastically increase intake air cooling capability and horsepower over the smaller stock intercooler. With a few supporting Mods and a tune These ecoboosts will outrun a 5.0 , The torque numbers are crazy.
Pressure tested to 40 psi
75% more internal flow space than stock
Reduce Intake Temps 40 degrees
21 x 6 x 5.5 inch core
2.5″ ID in / outlet
Cast Aluminum End Tanks
Bar and Plate Core
Aluminum Mounting Brackets
Fits with OEM Charge Pipe
Fits with OEM Engine Cover
Direct OEM Replacement
Retains stock active grille shutters, maintaining ideal aerodynamics when cooling demands are lower
No need to remove Bumper , no trimming, great fit.
Also see my Ecoboost Mustang intercooler pipe kit
2.5″ ID in / outlet
Bar and Plate Core
