Installed my catless down pipe 2 days ago and the check engine light turned on. I've heard it's normal when running a catless dp without a turn. Now if I buy a Cobb accessport and use their ots tunes will it automatically turn off or do I need to get a custom tune for my car?
· Premium Member
The CEL is caused due to your O2 sensor. With no cat there's no need for a rear O2 sensor. You need to turn that sensor off in the tune.
If the OTS tune is specifically designed for use with a cat-less DP it will have the rear 02 sensor turned off in it I would think and it should cure your CEL. However I'm not familiar with a Cobb OTS tune and what the different parameter changes are. I just went to their website and read this though....
"COBB currently only has Off-the-shelf (OTS) maps available for the 2.3L EcoBoost Mustangs. Custom maps and custom tuning support will be available in the near future."
So after reading that I would say that you will in fact require a custom tune.
You will get a CEL with the Cobb OTS maps. To eliminate that occurrence, you'd have to get a Protune (custom map) from a Cobb Protuner.
Some people make O2 foulers as a solution. It involves combining a couple of spark plug non-foulers that you can pick up at Advance Auto or AutoZone for a few bucks. Try Googling 'O2 fouler' and you'll quickly see what I'm referring to.
The best solution would be to have it turned off in the tune, but if you want it gone before you purchase a custom tune, then there's other options available.
