1 - 6 of 6 Posts
Like detailed in the topic my 2017 Ecoboost idles rough from time to time I noticed it this time when the tank dropped below 1/2 and I'm pretty sure it was the same scenario last time. It only has 40k on the dash so I know it's probably time for a tune up, but was trying to hold off until next month for that. I had 91 octane in the tank before both fill ups, and put 93 then when the tank got down to 1/2 it started acting funny. Could it be that now my tanks down to 1/2 it's finally pushing straight 93, and the computer is just trying to adjust for that? I filled up at Kum&go this time, the first time I filled up at a Valero so I figured I'd wait a cycle before putting 93 back in it to try and flush the bad gas out if it was that. Like I said it was running fine, and only does this when it drops to around about a half a tank on 93 octane
· Premium Member
Doubt if it is octane related. When you add half a tank of 93 to a tank that's half full of 91 you end up with a full tank of 92. The gas mixes as you fill it up and drive it so there's no separation of the two.
There should be no reason a "tune-up" is necessary at 40K. What does a 40K mile tune-up even involve anyway?
Sounds like you may have some water in your tank. Have you tried running the tank almost dry and then filling up with a full tank of good 93 octane from a Top Tier station?
Valero is a name brand fuel station and their do sell "Top Tier" detergent gasoline, how I would never trust gas from a Kum & Go, Circle K, Kangaroo, 7-11, etc.
I've tried running 93 Octane and haven't seen any measurable benefit. I track fuel economy and that definitely didn't improve when I used 93 octane (this surprised me). Subjectively the performance seemed the same. I suppose if I did actual HP / 0-60 measurements there might be a difference but since I can't tell the difference in everyday usage I cannot justify paying 20% to 30% more for premium.
Around here some (not all) Circle K's and Kangaroo Station actually sell brand name Top Tier Fuel. I regularly stop at a Circle K that sell Shell Gasoline and occasionally stop at a Kanagaroo that sells BP gasoline. I also buy a lot of gas at Costco which is Top Tier gasoline.
One thing to consider if you start having fuel problems when the fuel tank is half full is the performance of the right side fuel transfer unit. Mustangs have a double / split bottom fuel tank. Except when the tank is mostly full, fuel has to be transferred from the right side to the left side (where the main pump is located) to completely empty the tank. If the fuel transfer unit isn't performing properly, then it is possible you are actually running low on fuel if the left side of the tank even though the gauge may indicate a half full tank.
Ed
· Premium Member
Been so long since I've visited any of those establishments I hadn't noticed they started carrying the TT fuels. Nice to know I could hit one up if I needed to.
Ed
I completely forgot Ford has been doing the dual tank thing since the S197 platform. Great for overall weight balance. Sucks because it complicates the fuel system.
I hooked up a ob2 reader the day after the problem persisted, and again with 93 being ran in my tank it showed a bad gas/too lean fuel code on the scanner. Idk what's going on I've seen a lot of people running 93 in these cars without a problem. The only thing I can think of is maybe it's got a 91 tune? Because I run 91 without a issue and have been running 91 since I bought the car except a couple tanks of 93. On the tune up a couple threads I've read say you should change the spark plugs in these engines or at least check them at 30k https://www.cjponyparts.com/resources/mustang-general-maintenance check out here
· Premium Member
Tuned for 91 and running 93 won't affect anything, however if you were tuned for 93 and were running 91 that would be a different story.
As for replacing spark plugs at 30K... that's just a marketing ploy to get you to spend your hard earned money needlessly. Ford states the plugs are good for 100K.
1 - 6 of 6 Posts
